Topic: Acceptable fuel "cell" RCI Tank
I have read the rules:
The fuel-tank area must be totally separated from the driving compartment. For example, if the fuel tank is in the trunk area, any openings between the trunk and the cockpit must be permanently sealed with bolted, riveted, or welded metal panels. OE fuel tanks that are separate from, and located completely below, the trunk floor or rear-cabin floor are acceptable. If the fuel tank can't be completely separated from the cockpit by metal panels, a metal-encased, FIA-certified fuel cell with all related compliant fittings must be used.
This is what I am considering. This is not my build but one similar.
There will be 2 firewalls between Driver and RCI Fuel tank and an outside frame of the car as well as reinforcement around the tank.
Thoughts?
