Re: alternative fuels?
OMGuar wrote:I can buy junkyard turbo's and intercoolers for $75.00 each.. That's $150.00 and aftermarket FMU's (used they sell for about $35.00-45, new they are only $85.00) will allow me to enrich the fueling enough to take advantage of the boost..
hm, let me work on some simple math here.
Used Jag = $400
2 junk yard turbos and intercooler =$150
Plumbing costs to connect all that together =$100
2 FMUs x 35 = $70
Transmission mods from previous e-mails $50
Cheater suspension mods = $150
Total = $820
Doesn't matter does it if you are right does it? However,
Don't know where you figure the suspension mods from, I'll simply cut the stock springs to lower the car, melt the rubber out of the subframe mounts and reweld them together. that and weight reduction should make things OK..
The transmission mod is simply a old ball bearing from a junk transmission and some epoxy. Maybe a few cents?
plumbing? It will be old junk likely from the car, don't think it has enough weight to have any scrap value..
And only one FMU is required.
Now the real question is the value of the car..
I got three of them free from a Junk yard that needed the space for cars that he sells a lot of parts for (BMW's, Volvo's, and Saabs) He's had them in his place for over a decade with only trivial sales..
However that doesn't matter. What matters is the asigned value of a car. You can get free or near free Mazda MX5's and they are valued at around $500.00 Certain BMW's are valued similarly.. A 34 year old car not known for reliability? well OK $400 or maybe just $350.00 maybe even $500..
Doesn't matter does it?
The successfull cars will run about 2 hours betwen gas stops.. (street driven they get between 30-40 MPG) The Jag got 8-11 MPG so it will need a fuel stop every 40 minutes.. switch to methanol it will need a fuel stop every 15-20 minutes that's about 100 fuel stops to what? 11-12? in a 24 hour race?
In a car not kown for reliability?
If you aren't rolling on the floor blowing snot with tears rushing from your eyes you simply have no sense of humor..
